Flip the keyboard upside down so the bottom is angled towards you.
  • Flip the keyboard upside down so the bottom is angled towards you.
Agregar Comentario
Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
  • Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
Agregar Comentario
Remove the bottom panel by lifting the bottom panel up and outward from yourself.
  • Remove the bottom panel by lifting the bottom panel up and outward from yourself.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop. Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
  • Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop.
  • Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
Agregar Comentario
Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
  • Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
  • Completely unscrew and remove all four screws in the corners of the speaker.
Agregar Comentario
Pull the speaker out of the keyboard and set on a flat surface to solder safely.
  • Pull the speaker out of the keyboard and set on a flat surface to solder safely.
Agregar Comentario
Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
  • Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
  • Touch soldering iron to solder over the end of the wires, and when the solder melts, pull the wires away from the speaker.
  • Remove the speaker and replace with a new one.
Agregar Comentario
Strip the wires if you need more clean metal to solder to the speaker.
  • Strip the wires if you need more clean metal to solder to the speaker.
  • Use the soldering iron to melt the solder over the wire to connect them to the speaker.
Agregar Comentario
Completely screw in the screws back into the original positions on the corner of the speaker.
  • Completely screw in the screws back into the original positions on the corner of the speaker.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Jimmy Winne
Miembro Desde 04/10/12
422 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 9-16, Amido Fall 2012 Miembro de Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 13
Últimos 30 Días: 56
Todo El Tiempo: 3,315
