Saltar al contenido principal
Casio CTK-501 LCD Screen Replacement
Qué necesitas
  1. Casio CTK-501 LCD Screen Replacement, Bottom Panel: paso 1, imagen 1 de 2 Casio CTK-501 LCD Screen Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 LCD Screen Replacement: paso 3, imagen 1 de 2 Casio CTK-501 LCD Screen Replacement: paso 3, imagen 2 de 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 1
    • Completely unscrew and remove all six of the screws on the central circuit board.
  5. Casio CTK-501 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Lift the circuit board out of your way.
  6. Casio CTK-501 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Remove tape from the LCD screen and remove the screen completely.
  7. Casio CTK-501 LCD Screen Replacement: paso 7, imagen 1 de 2 Casio CTK-501 LCD Screen Replacement: paso 7, imagen 2 de 2
    • Replace the LCD screen and tape it down to the top cover.
  8. Casio CTK-501 LCD Screen Replacement: paso 8, imagen 1 de 1
    • Place the circuit board back on top of the LCD screen.
    • Screw all of the screws completely in their original positions.
Conclusión
2 personas más completaron esta guía.
Jimmy Winne
Miembro Desde 10/04/12
578 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 9-16, Amido Fall 2012 Miembro de Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Miembros
6 Guías creadas
3 comentarios
Where did you get the replacement LCD screen? I'm looking for one for my CTK-573 keyboard mbuseck1@yahoo.com
mbuseck1 - Contestar
Hi. Would this screen work for CTK 481?
José Saldaña - Contestar
hi. I have the ctk 4300. i would like to know where i can get one.Binitintimo@gmail.com
timo binitin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 5,028
