Flip the keyboard upside down so the bottom is angled towards you.
  • Flip the keyboard upside down so the bottom is angled towards you.
Agregar Comentario
Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
  • Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
Agregar Comentario
Remove the bottom panel by lifting the bottom panel up and outward from yourself.
  • Remove the bottom panel by lifting the bottom panel up and outward from yourself.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop. Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
  • Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop.
  • Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
Agregar Comentario
Completely unscrew and remove the screws holding the broken string of keys  in place.
  • Completely unscrew and remove the screws holding the broken string of keys in place.
Agregar Comentario
Pull up the top layer of white keys to remove them from the keyboard.
  • Pull up the top layer of white keys to remove them from the keyboard.
Agregar Comentario
Pull up on the last layer of white keys to remove them.
  • Pull up on the last layer of white keys to remove them.
Agregar Comentario
Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
  • Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
Agregar Comentario
Replace the group of broken keys with new ones and screw all of the keys back in place.
  • Replace the group of broken keys with new ones and screw all of the keys back in place.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Jimmy Winne
Miembro Desde 04/10/12
422 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 9-16, Amido Fall 2012 Miembro de Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Miembros
6 Guías creadas
my ctk710 keybord circuit failure.... how to get new circuit in online plg help me
michael Akhil - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 10
Últimos 7 Días: 48
Últimos 30 Días: 239
Todo El Tiempo: 13,050
