Partes
No se requieren partes.
Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen. Remove the 2 screws(4.08mm) on the other side.  One is located under the rubber USB flap. Remove the last screw(2.59mm) located on the bottom of the camera.
  • Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen.
  • Remove the 2 screws(4.08mm) on the other side. One is located under the rubber USB flap.
  • Remove the last screw(2.59mm) located on the bottom of the camera.
  • Slowly pull the back cover of the camera.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Unplug the green (if color-blind please ask someone for assistance) and white plugs connecting the top panel to  top of the logic board. Dislodge the tab above the lens.
  • Unplug the green (if color-blind please ask someone for assistance) and white plugs connecting the top panel to top of the logic board.
  • Dislodge the tab above the lens.
  • Dislodge the back tab.
Agregar Comentario
Conclusión
Robert Manno
Miembro Desde 05/01/11
432 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-3, Forte Winter 2011 Miembro de Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 893
