Introducción
The screen is a crucial part of the camera: it displays images for consumers to view their pictures instantly. Damage to the screen may require replacement.
Partes
No se requieren partes.
Slide grey latch to open the battery compartment. Slide grey latch to open the battery compartment.
  • Slide grey latch to open the battery compartment.
Agregar Comentario
Push orange retaining clip to the right to free battery. Push orange retaining clip to the right to free battery.
  • Push orange retaining clip to the right to free battery.
Agregar Comentario
Remove battery from the camera.
  • Remove battery from the camera.
Agregar Comentario
Remove the lanyard.
  • Remove the lanyard.
Agregar Comentario
Remove the two 2.3mm screws (underneath the name plate) and two 2.8mm screws (next to the threaded tripod mount) from the bottom face of the camera.
  • Remove the two 2.3mm screws (underneath the name plate) and two 2.8mm screws (next to the threaded tripod mount) from the bottom face of the camera.
  • Be careful to keep track of the different screw sizes as you proceed with this guide.
Agregar Comentario
Remove the single 3.8mm screw from the back face of the camera.
  • Remove the single 3.8mm screw from the back face of the camera.
Agregar Comentario
Remove the two 2.3mm screws from the right face of the camera.
  • Remove the two 2.3mm screws from the right face of the camera.
Agregar Comentario
Remove the two 3.2mm screws (outside edge) and two 3.7mm screws (towards middle) from the left side of the camera body.
  • Remove the two 3.2mm screws (outside edge) and two 3.7mm screws (towards middle) from the left side of the camera body.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
Agregar Comentario
Remove the CF card door from the left side of the camera body. Remove the CF card door from the left side of the camera body.
  • Remove the CF card door from the left side of the camera body.
Agregar Comentario
Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate. Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate.
  • Remove the rubber digital a/v out cap by sliding it out of the groove on the front plate.
Agregar Comentario
Remove the front face by sliding it off.
  • Remove the front face by sliding it off.
Agregar Comentario
Remove the rubber seal that goes over the right side of the viewfinder.
  • Remove the rubber seal that goes over the right side of the viewfinder.
Agregar Comentario
Remove the two 3.9mm screws that retain the laminated cooper sheet.
  • Remove the two 3.9mm screws that retain the laminated cooper sheet.
Agregar Comentario
Remove the seven wire connections that connect to the motherboard. Remove the seven wire connections that connect to the motherboard.
  • Remove the seven wire connections that connect to the motherboard.
Agregar Comentario
Remove the single 3.8mm screw that is on the motherboard.
  • Remove the single 3.8mm screw that is on the motherboard.
Agregar Comentario
Carefully remove the motherboard from the main frame of the camera body.
  • Carefully remove the motherboard from the main frame of the camera body.
Agregar Comentario
After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
  • After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
Agregar Comentario
Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
  • Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
Agregar Comentario
Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
  • Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
  • Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
Agregar Comentario
Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
  • Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
Agregar Comentario
Unsolder the four points at the top of the screen with a soldering iron
  • Unsolder the four points at the top of the screen with a soldering iron
Agregar Comentario
Conclusión
Anh
Miembro Desde 13/04/11
121 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 20-70, Walters Spring 2011 Miembro de Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 1,367
