Saltar al contenido principal
Canon Powershot S200 Motherboard Replacement
Qué necesitas
  1. Canon Powershot S200 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Canon Powershot S200 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Motherboard Replacement: paso 2, imagen 1 de 2 Canon Powershot S200 Motherboard Replacement: paso 2, imagen 2 de 2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove battery from the camera.
  4. Canon Powershot S200 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 1
    • Remove the lanyard.
  5. Canon Powershot S200 Motherboard Replacement: paso 5, imagen 1 de 1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Motherboard Replacement: paso 9, imagen 1 de 1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Motherboard Replacement: paso 10, imagen 1 de 2 Canon Powershot S200 Motherboard Replacement: paso 10, imagen 2 de 2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Motherboard Replacement: paso 11, imagen 1 de 2 Canon Powershot S200 Motherboard Replacement: paso 11, imagen 2 de 2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Motherboard Replacement: paso 12, imagen 1 de 1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Motherboard Replacement: paso 15, imagen 1 de 2 Canon Powershot S200 Motherboard Replacement: paso 15, imagen 2 de 2
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Motherboard Replacement: paso 16, imagen 1 de 1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Motherboard Replacement: paso 17, imagen 1 de 1
    • Remove the motherboard from the main frame of the camera body.
Conclusión
Orlando Zuniga
Miembro Desde 04/14/11
11 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 20-70, Walters Spring 2011 Miembro de Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,879
