Introducción
This guide will help you replace the speaker inside your Canon Powershot A70 camera. The speaker is a simple part, but due to how often it is used, it can often run into issues and need to be replaced. Due to the number of steps, and small parts, this guide is considered moderately difficult but there are no special skills needed to complete this fix. Be sure to keep all of the screws of the camera in a place where you will not lose them!
Qué necesitas
Open the battery compartment and remove the batteries.
Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
Remove the wrist strap.
Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
Remove the two clearly visible screws from the control dial with a Phillips #00 screwdriver.
Remove the dial—it should come off easily.
Una persona más ha completado esta guía.
