Introducción
How to remove the outer casing of your Canon PowerShot SD870 IS.
Partes
No se requieren partes.
Remove the wrist strap, if present.
  • Remove the wrist strap, if present.
  • Remove the lithium-ion battery.
Agregar Comentario
Remove the two 4 mm Phillips #00 screws on the bottom of the camera. Remove the screw next to the wrist strap attachment. Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
  • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
  • Remove the screw next to the wrist strap attachment.
  • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
Note: The PH000 bit from my iFixit toolkit fits the screws better than the PH00 described above. The 00 bit is too pointed to bottom out in the screw and therefore does not engage as well.
wayne - Contestar
Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
  • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
With the camera I was repairing, to remove the front cover as shown below, it was necessary to first remove the two smaller screws on the opposite end of the body from the “A/V OUT DIGITAL” cover. That is . . . the screws shown in step 5 which in my camera also hold the front cover in place (design change apparently).
RWM
wayne - Contestar
Pull the front cover from the camera by  using gentle upward pressure. Pull the front cover from the camera by  using gentle upward pressure.
  • Pull the front cover from the camera by using gentle upward pressure.
Agregar Comentario
Remove the two Phillips #00 screws from the flat end of the camera. Remove the black L-shaped side cover plate.
  • Remove the two Phillips #00 screws from the flat end of the camera.
  • Remove the black L-shaped side cover plate.
  • Remove the silver u-shaped retainer plate.
Agregar Comentario
Slide the back casing off.
  • Slide the back casing off.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Zach pelley
Miembro Desde 19/04/10
58 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-45, Garner Spring 2010 Miembro de Cal Poly, Team 10-45, Garner Spring 2010
CPSU-GARNER-S10S10G45
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 7,796
