Saltar al contenido principal
Canon PowerShot SD850 IS Battery Replacement
  1. Canon PowerShot SD850 IS Battery Replacement, Battery: paso 1, imagen 1 de 3 Canon PowerShot SD850 IS Battery Replacement, Battery: paso 1, imagen 2 de 3 Canon PowerShot SD850 IS Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Battery Replacement: paso 2, imagen 1 de 2 Canon PowerShot SD850 IS Battery Replacement: paso 2, imagen 2 de 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
Conclusión
To reassemble your device, follow thee instructions in reverse order.
Peter Tran
Miembro Desde 10/06/10
225 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 20-7, Maness Fall 2010 Miembro de Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 27
Todo El Tiempo: 2,986
