Introducción
You can replace the flash if it stops working.
Partes
No se requieren partes.
Remove one 2.25mm screw on the bottom.
  • Remove one 2.25mm screw on the bottom.
Agregar Comentario
Remove two 2.25mm screws on the right side looking from the front.
  • Remove two 2.25mm screws on the right side looking from the front.
Agregar Comentario
Remove one 4.7mm screw on the side with the AV output.
  • Remove one 4.7mm screw on the side with the AV output.
Agregar Comentario
Pull off the back cover.
  • Pull off the back cover.
  • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
Agregar Comentario
Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
  • Remove the 3.9mm screw in the AV housing on the left side from the front of the camera.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove one 2.25mm screw on the bottom of the camera.
  • Remove one 2.25mm screw on the bottom of the camera.
Agregar Comentario
Pull off the front cover.
  • Pull off the front cover.
Agregar Comentario
Remove 2 2.4mm screws on bottom.
  • Remove 2 2.4mm screws on bottom.
Agregar Comentario
Follow the small data cable to where it connects to the camera.
  • Follow the small data cable to where it connects to the camera.
  • Lift the back white portion to unlock the cable.
  • The cable should easily slide out.
  • The connector is very fragile. Use caution when lifting the lock.
Agregar Comentario
Gently lift LCD display off.
  • Gently lift LCD display off.
  • There will be two data cables still attached to the camera. Do not break them.
  • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
Agregar Comentario
Follow the larger cable to where it connects to the camera.
  • Follow the larger cable to where it connects to the camera.
  • Lift the front black portion of the connector to unlock the data cable.
Agregar Comentario
Remove one 3.9mm screw from inner frame.
  • Remove one 3.9mm screw from inner frame.
  • NEW: Steps 8–11 (Removing the LCD Assembly) are unnecessary and can be skipped!!! Instead of the step shown here, you may access the Flash Assembly from the side of the camera—unscrewing it from the metal bracket that is attached to the inner frame. (The bracket will be clearly visible after removing the back and front covers—sorry, no photo!) Note that the Flash Assembly is also held to the bracket by 2 small posts along its plastic body; after unscrewing, pull the assembly gently away from the bracket to unseat the posts.
Agregar Comentario
Follow the data cable to where it connects to the camera.
  • Follow the data cable to where it connects to the camera.
  • Lift up the back black portion to unlock the data cable.
Agregar Comentario
Gently pull the red and black wires, lifting the white connector upwards, out of its position. (You may need to jiggle the wires from side to side somewhat to loosen the connector.)
  • Gently pull the red and black wires, lifting the white connector upwards, out of its position. (You may need to jiggle the wires from side to side somewhat to loosen the connector.)
  • Now that all cables and screws are disconnected, you can now remove the flash assembly.
  • To reinsert, line up connector with the copper leads on the camera, and gently press the white piece into place.
  • The black cable should be closer to the top of the camera.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Jeremy Rabaino
Miembro Desde 10/10/10
135 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 20-9, Maness Fall 2010 Miembro de Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,335
