Saltar al contenido principal
Canon PowerShot SD700 Motherboard Replacement
Qué necesitas
  1. Canon PowerShot SD700 Motherboard Replacement, Outside Case: paso 1, imagen 1 de 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 Motherboard Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 Motherboard Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 Motherboard Replacement, Motherboard: paso 7, imagen 1 de 1
    • Once the LCD and Backlight are detached, remove the larger screw marked in red in the picture as well as the four smaller sized screws marked in blue.
  8. Canon PowerShot SD700 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the two screws near the the tri-pod mount with a Philips head screw driver.
  9. Canon PowerShot SD700 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the screw next to the shutter with a Philip's head screw driver.
  10. Canon PowerShot SD700 Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the orange ribbon cable by lifting the ZIF connector attached to the ribbon with a flat head screw driver or spudger.
  11. Canon PowerShot SD700 Motherboard Replacement: paso 11, imagen 1 de 2 Canon PowerShot SD700 Motherboard Replacement: paso 11, imagen 2 de 2
    • Carefully lift the shutter along with the ribbon connected to it. This will remove the casing around the motherboard.
  12. Canon PowerShot SD700 Motherboard Replacement: paso 12, imagen 1 de 3 Canon PowerShot SD700 Motherboard Replacement: paso 12, imagen 2 de 3 Canon PowerShot SD700 Motherboard Replacement: paso 12, imagen 3 de 3
    • With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera.
  13. Canon PowerShot SD700 Motherboard Replacement: paso 13, imagen 1 de 2 Canon PowerShot SD700 Motherboard Replacement: paso 13, imagen 2 de 2
    • First remove the wires that are attached to the motherboard, as shown by the black box. You can detach them by simply pulling them out.
    • Next you can remove the film by lifting it gently from the motherboard.
  14. Canon PowerShot SD700 Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the last wires connected to the motherboard. You can remove it by gently lifting it upwards.
  15. Canon PowerShot SD700 Motherboard Replacement: paso 15, imagen 1 de 2 Canon PowerShot SD700 Motherboard Replacement: paso 15, imagen 2 de 2
    • Place a flathead screwdriver and gently lift the circuit attached, as shown on the picture.
  16. Canon PowerShot SD700 Motherboard Replacement: paso 16, imagen 1 de 2 Canon PowerShot SD700 Motherboard Replacement: paso 16, imagen 2 de 2
    • Remove the screw using a philip 00 screwdriver.
    • Once the screw is removed, gently lift the motherboard away from the case.
  17. Canon PowerShot SD700 Motherboard Replacement: paso 17, imagen 1 de 2 Canon PowerShot SD700 Motherboard Replacement: paso 17, imagen 2 de 2
    • Remove the screw as shown by the red circle.
    • Once the screw is removed, you can remove the board.
Conclusión
Kenneth Lim
Miembro Desde 04/07/11
61 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-71, Walters Spring 2011 Miembro de Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 1,332
