Introducción
You need to remove the casing before you can start getting into any internal parts of the Camera. This can also be a good start to helping the camera dry out in case of a water accident.
Partes
No se requieren partes.
Remove the battery and SD Card from their slots.  Leaving these in could cause the battery to ground and ruin the electronics.
  • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
  • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
Agregar Comentario
Pull the lanyard mount off of the camera using a spudger or your fingers.
  • Pull the lanyard mount off of the camera using a spudger or your fingers.
Agregar Comentario
Find the line that separates the casing into its two halves.  Hold each half seperately, and gently pull apart. Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  • Find the line that separates the casing into its two halves. Hold each half seperately, and gently pull apart.
  • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
Agregar Comentario
Take hold of the inside of the camera, and gently pull away from the back casing.
  • Take hold of the inside of the camera, and gently pull away from the back casing.
Agregar Comentario
Remove the square, clear, rubber protector from the front of the logic board.  This is not necessary to remove, but can easily fall off and get lost during later steps.
  • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
Agregar Comentario
When you reassemble the camera, make sure the switch on the casing (pictured left) matches the position of the switch on the camera internals.
  • When you reassemble the camera, make sure the switch on the casing (pictured left) matches the position of the switch on the camera internals.
  • The black viewfinder padding (pictured right) can easily fall off the casing. Make sure you don't lose it when moving around parts.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 25-85, Amido Spring 2010 Miembro de Cal Poly, Team 25-85, Amido Spring 2010
CPSU-AMIDO-S10S25G85
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 3,371
