Partes
No se requieren partes.
There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws) There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws) There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws)
  • There are 6 screws total that you need to remove in order to open the case (bottom and both sides, each has 2 screws)
Agregar Comentario
Carefully remove the exterior screws using a screwdriver and put them somewhere safe so they will not get lost. Carefully remove the exterior screws using a screwdriver and put them somewhere safe so they will not get lost. Carefully remove the exterior screws using a screwdriver and put them somewhere safe so they will not get lost.
  • Carefully remove the exterior screws using a screwdriver and put them somewhere safe so they will not get lost.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Remove the interior screws using screwdriver Remove the interior screws using screwdriver
  • Remove the interior screws using screwdriver
Agregar Comentario
Insert the flat-head screwdriver under the LCD screen into the two clips. Lift up the LCD screen. Be careful not to rip the screen off. Lift up the LCD screen. Be careful not to rip the screen off.
  • Insert the flat-head screwdriver under the LCD screen into the two clips.
  • Lift up the LCD screen. Be careful not to rip the screen off.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Yi Huang Ke
Miembro Desde 18/10/11
51 Reputación
4 Guías creadas
Equipo
James Madison, Team 1-1, Allen Fall 2011 Miembro de James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 Miembros
4 Guías creadas
Do you carry a lcd screen for the Powershot sd400?
Jesus Licon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 2,501
