Introducción
This guide should be used if our guide, "Cleaning Function Buttons", doesn't fix your function buttons.
Partes
No se requieren partes.
Remove wrist strap and battery. Remove wrist strap and battery.
  • Remove wrist strap and battery.
Agregar Comentario
Remove 2 screws from each side of the camera (4 total, 0.102 in). Remove 2 screws from the bottom on the camera (0.138 in). Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  • Remove 2 screws from each side of the camera (4 total, 0.102 in).
  • Remove 2 screws from the bottom on the camera (0.138 in).
  • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
Agregar Comentario
Gently pull off the front cover. The plate on the side should come off. Gently pull off the back cover.
  • Gently pull off the front cover.
  • The plate on the side should come off.
  • Gently pull off the back cover.
Agregar Comentario
The cases should now be removed.
  • The cases should now be removed.
This can be a bit tricky when reassembling. All of the little tabs around the edge need to snap into their proper places, and there are three cover pieces to manage. Plus, you need to make sure that the camera/video/playback switch is properly engaged with its slider on the circuit board, otherwise you'll need to raise the back panel and reposition everything again.
Craig Bonsignore - Contestar
oh yes , i agree lol
elbala80 -
Use the spudger to disconnect the black tab.
  • Use the spudger to disconnect the black tab.
Agregar Comentario
Gently pull off the shutter button assembly.
  • Gently pull off the shutter button assembly.
Agregar Comentario
Use the tweezers to disconnect the microphone cable.
  • Use the tweezers to disconnect the microphone cable.
Agregar Comentario
The shutter button assembly should now be removed.
  • The shutter button assembly should now be removed.
Agregar Comentario
With the spudger, flip up the black tab on the main ribbon.
  • With the spudger, flip up the black tab on the main ribbon.
Agregar Comentario
Gently pull straight out on the ribbon to disconnect it from the logic board. Gently pull straight out on the ribbon to disconnect it from the logic board.
  • Gently pull straight out on the ribbon to disconnect it from the logic board.
Agregar Comentario
By hand, gently unfold the function button board and lift it off the frame.
  • By hand, gently unfold the function button board and lift it off the frame.
Agregar Comentario
Congratulations! The function button board can now be replaced.
  • Congratulations! The function button board can now be replaced.
Agregar Comentario
Conclusión
Wyatt Chan
Miembro Desde 05/01/11
235 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-32, Regan Winter 2011 Miembro de Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 1,790
