Introducción
This guide serves to replace a faulty flash mechanism.
Remove the knot on the wrist lanyard. Remove the battery and memory card.
  • Remove the knot on the wrist lanyard.
  • Remove the battery and memory card.
Agregar Comentario
Remove all screws from sides of outer casing. Begin removing the screws on the bottom of the outer casing.
  • Remove all screws from sides of outer casing.
  • Begin removing the screws on the bottom of the outer casing.
  • Remove the rest of the screws from the outer casing.
Agregar Comentario
Gently pull the front cover off the camera. Gently pull the front cover off the camera. Gently pull the front cover off the camera.
  • Gently pull the front cover off the camera.
Agregar Comentario
Open the "A/V Out Digital" cover slide, and remove the screw inside. Gently pull off the back casing. Remove the black "L" shaped piece of metal.
  • Open the "A/V Out Digital" cover slide, and remove the screw inside.
  • Gently pull off the back casing.
  • Remove the black "L" shaped piece of metal.
Agregar Comentario
Remove the three screws that are holding the screen in place and free the screen from the underlying components.
  • Remove the three screws that are holding the screen in place and free the screen from the underlying components.
  • Be careful of the ribbon wire that is still attached on the left of the screen.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place. Unplug the wide ribbon cable.
  • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
  • Unplug the wide ribbon cable.
  • Unplug the narrow ribbon cable to free the LCD screen from the camera body
The author failed to mention a couple things. First, the screen is in a holder which you remove, then after pulling off some electrical tape, you have to yank the actual screen out. Second, I only had two screws to pull the screen holder out, not three. Third, the thing that you have to pull to get the screen ribbon cable out is actually a tiny black hinge, so don't worry if it suddenly snaps back. Finally, to put the thing back together, it really helps if you have a tweezers to get the ribbon cables back into place.
and fyi replacement screens available from canon parts department for about 50 bucks.
steven - Contestar
Remove the L-shaped corner trim containing the picture button.
  • Remove the L-shaped corner trim containing the picture button.
  • Carefully unplug the connection cable attached.
Agregar Comentario
Pull the selector wheel from the top corner of the camera. With a set of tweezers, carefully remove the ribbon cable connection.
  • Pull the selector wheel from the top corner of the camera.
  • With a set of tweezers, carefully remove the ribbon cable connection.
Agregar Comentario
Unscrew the zoom toggle switch and remove.
  • Unscrew the zoom toggle switch and remove.
Agregar Comentario
Unscrew the flash board.
  • Unscrew the flash board.
Agregar Comentario
With a metal spudger, gently pry up and remove the cable connection.
  • With a metal spudger, gently pry up and remove the cable connection.
  • With a metal spudger, gently lift up black tab to remove ribbon cable.
Agregar Comentario
Lift the flash bulb unit from the camera.
  • Lift the flash bulb unit from the camera.
Agregar Comentario
Lift the entire three-part flash assembly from the camera. Lift the entire three-part flash assembly from the camera.
  • Lift the entire three-part flash assembly from the camera.
Agregar Comentario
Conclusión
BrettH
Miembro Desde 28/10/09
219 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 19-5, Maness SU 2012 Miembro de Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 Miembro
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 3,422
