Introducción
This guide describes how to remove the battery casing for cleaning and to check the connections with the rest of the camera.
Unscrew five Phillips screws using a #0 Phillips screwdriver. One screw is on upper right corner of the back panel.
  • Unscrew five Phillips screws using a #0 Phillips screwdriver.
  • One screw is on upper right corner of the back panel.
  • The other four screws are on the bottom of the camera.
Agregar Comentario
Open memory card cover by moving the slide switch toward the top end of of the camera.
  • Open memory card cover by moving the slide switch toward the top end of of the camera.
  • Remove the memory card from the slot.
Agregar Comentario
Remove the rear cover from the rest of the camera.
  • Remove the rear cover from the rest of the camera.
  • This may require gentle rocking of the case to free it.
Agregar Comentario
Unscrew the four Philips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver. Unscrew the four Philips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
  • Unscrew the four Philips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
Agregar Comentario
Free the front cover from the rest of the camera.
  • Free the front cover from the rest of the camera.
  • The cover may require gentle rocking to remove.
Agregar Comentario
Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
  • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
Agregar Comentario
Gently separate the top of LCD from the rest of the camera using your thumb.
  • Gently separate the top of LCD from the rest of the camera using your thumb.
  • Be careful not pull the LCD too far because of the ribbon cable connection.
  • Place the Spudger in the hole of the electrical ribbon.
  • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
  • The LCD will still be connected to the rest of the camera
Agregar Comentario
Unscrew single Phillips screw with a #0 Phillips screwdriver. Free the bottom panel and attached ribbon from the rest of the camera.
  • Unscrew single Phillips screw with a #0 Phillips screwdriver.
  • Free the bottom panel and attached ribbon from the rest of the camera.
  • Be careful not to damage the ribbon.
Agregar Comentario
Turn over the camera.
  • Turn over the camera.
  • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
  • The plastic will still be connected on the left side.
Agregar Comentario
Place the Spudger between the orange ribbon and the black ribbon gate.
  • Place the Spudger between the orange ribbon and the black ribbon gate.
  • Lift the ribbon gate using the Spudger.
Agregar Comentario
Place the Spludger in the corner of the ribbon above the hole.
  • Place the Spludger in the corner of the ribbon above the hole.
  • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Free this ribbon and the bottom panel from the rest of the camera.
  • Free this ribbon and the bottom panel from the rest of the camera.
Agregar Comentario
Turn the camera over so you can see the LCD.
  • Turn the camera over so you can see the LCD.
  • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
Agregar Comentario
Lift the blue ribbon gate using the Spudger.
  • Lift the blue ribbon gate using the Spudger.
Agregar Comentario
Insert the Spudger into the hole of the ribbon.
  • Insert the Spudger into the hole of the ribbon.
  • Move the Spudger away from the gate to fully remove ribbon.
Agregar Comentario
Lift the LCD away from the rest of the camera.
  • Lift the LCD away from the rest of the camera.
Agregar Comentario
Lift off the capture button by wiggling it back and forth while pulling upward. Be careful not to damage the two clips.
  • Lift off the capture button by wiggling it back and forth while pulling upward.
  • Be careful not to damage the two clips.
Agregar Comentario
Flip open the four ribbon gates using the Spudger. Gently pull out the ribbon cables from the gates using the Spudger.
  • Flip open the four ribbon gates using the Spudger.
  • Gently pull out the ribbon cables from the gates using the Spudger.
Agregar Comentario
Unscrew the four Phillips screws using a #0 Phillips screwdriver.
  • Unscrew the four Phillips screws using a #0 Phillips screwdriver.
Agregar Comentario
Gently lift the the logic board. Be careful not to pull too hard and damage the white ribbon cable.
  • Gently lift the the logic board.
  • Be careful not to pull too hard and damage the white ribbon cable.
  • Place the Spudger so that it is between the logic board, the white ribbon cable, and the rest of the camera.
  • Remove the white ribbon cable by pulling the Spudger away from the camera, keeping it parallel to the logic board.
Agregar Comentario
Lay the logic board back down so that it is resting on the body of the camera.
  • Lay the logic board back down so that it is resting on the body of the camera.
  • Pull the two plugs (white and green) out to the right from the logic board using the tweezers.
Agregar Comentario
We're now ready to begin the desoldering process. You'll need a soldering iron, solder, and desoldering wick. You should be able to find these items at a Radio Shack if you don't already have them. Please do not perform this step if you are not comfortable or have previous experience with soldering.  Doing so, could cause severe damage to your camera.
  • We're now ready to begin the desoldering process. You'll need a soldering iron, solder, and desoldering wick. You should be able to find these items at a Radio Shack if you don't already have them.
  • Please do not perform this step if you are not comfortable or have previous experience with soldering. Doing so, could cause severe damage to your camera.
  • Desolder the two soldered ribbon cables attached to the logic board.
Agregar Comentario
Free the logic board from the rest of the camera.
  • Free the logic board from the rest of the camera.
Agregar Comentario
Turn the camera over so that the back is facing you.
  • Turn the camera over so that the back is facing you.
  • Unscrew the three Phillips Screws using a #0 Phillips screwdriver.
Agregar Comentario
Lift off the Memory Card casing, sliding the ribbon cable through the camera. Keep pulling until the Memory Card and ribbon cable have been removed from the camera. Note that the ribbon cable is coming from the external front portion of the camera. Make sure that the ribbon cable will not get caught on anything.
  • Lift off the Memory Card casing, sliding the ribbon cable through the camera. Keep pulling until the Memory Card and ribbon cable have been removed from the camera.
  • Note that the ribbon cable is coming from the external front portion of the camera. Make sure that the ribbon cable will not get caught on anything.
Agregar Comentario
Unscrew one Phillips screws from the side and three Phillips screws from the back panel using a #0 Phillips screwdriver. Unscrew one Phillips screws from the side and three Phillips screws from the back panel using a #0 Phillips screwdriver.
  • Unscrew one Phillips screws from the side and three Phillips screws from the back panel using a #0 Phillips screwdriver.
Agregar Comentario
Firmly push on the back of the zoom lens, removing it from the left portion of the camera. Lift the zoom lens away from the left portion of the camera so that there are three components connected by a ribbon cables. Be careful not to tear the ribbon cables.
  • Firmly push on the back of the zoom lens, removing it from the left portion of the camera.
  • Lift the zoom lens away from the left portion of the camera so that there are three components connected by a ribbon cables.
  • Be careful not to tear the ribbon cables.
Agregar Comentario
The camera should now be able to be set in this orientation without too much stress on the cables.
  • The camera should now be able to be set in this orientation without too much stress on the cables.
  • The clear plastic is still attached to the battery casing.
Agregar Comentario
Locate the ribbon cable going from the battery case to the flash assembly. Remove the plug from the ribbon cable using the tweezers.
  • Locate the ribbon cable going from the battery case to the flash assembly.
  • Remove the plug from the ribbon cable using the tweezers.
  • The flash assembly is now free from the rest of the camera.
Agregar Comentario
Pick up the remaining battery casing and zoom lens.
  • Pick up the remaining battery casing and zoom lens.
  • Pull off the clear plastic.
  • The clear plastic is secured by adhesive along the bottom edge and a small hook.
Agregar Comentario
Lift the zoom lens off of the battery casing.
  • Lift the zoom lens off of the battery casing.
  • The back of the circuits are attached to the battery casing by a light adhesive, which can be removed with a slight pull upwards.
Agregar Comentario
The remaining pieces from left to right are: the battery casing, zoom lens and flash assembly.
  • The remaining pieces from left to right are: the battery casing, zoom lens and flash assembly.
Agregar Comentario
Check the battery terminals for any corrosive material or bad connections.
  • Check the battery terminals for any corrosive material or bad connections.
Agregar Comentario
Conclusión
Nathan Balcom
Miembro Desde 21/01/10
81 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 16-28, Maness Winter 2010 Miembro de Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,884
