Introducción
This guide will show you how to remove and replace the button panel on the top of the camera.
Partes
No se requieren partes.
Turn the camera with the bottom side facing up. Locate the panel labeled "Batt. Open"
  • Turn the camera with the bottom side facing up.
  • Locate the panel labeled "Batt. Open"
  • Place your finger on the panel and slide it in the direction of the arrow.
  • The slot will swing open revealing the battery pack.
Agregar Comentario
Rotate the camera so that the slot is horizontal.
  • Rotate the camera so that the slot is horizontal.
  • Pull the orange lever and the battery will spring out slightly.
Agregar Comentario
Grasp battery and fully pull out of slot
  • Grasp battery and fully pull out of slot
  • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
Agregar Comentario
Start by laying the camera flat with the LCD screen facing up.
  • Start by laying the camera flat with the LCD screen facing up.
  • Remove the 3.8mm screw in the upper right corner.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Position the camera with the bottom facing up.
  • Position the camera with the bottom facing up.
  • Remove the 4.8mm screw.
  • Remove the two 2.3mm screws.
Agregar Comentario
Position the camera so that the rubber "AV Out Digital" tab is facing upward. Slide this rubber tab out of the way to reveal the bottom screw.
  • Position the camera so that the rubber "AV Out Digital" tab is facing upward.
  • Slide this rubber tab out of the way to reveal the bottom screw.
  • Remove the two 3.7mm screws.
Agregar Comentario
Turn the camera with the back side facing you.
  • Turn the camera with the back side facing you.
  • Grip the edges of the back plate, and carefully slide it off.
  • If there is any resistance in movement, double check there are no screws left in the chassis.
Agregar Comentario
Orientate the camera as in the picture. Remove the two 2.3mm outer screws.
  • Orientate the camera as in the picture.
  • Remove the two 2.3mm outer screws.
  • Remove the two 3.8mm screws near the strap bracket.
  • Remove small panel covering mounting bracket.
  • Remove door covering memory card.
Agregar Comentario
Rotate the camera so that the bottom side is facing you.
  • Rotate the camera so that the bottom side is facing you.
  • Remove the 3.8mm screw below the mounting bracket.
Agregar Comentario
Rotate the camera so that the front is facing you.
  • Rotate the camera so that the front is facing you.
  • Grasp sides of front cover and carefully pull the front panel off of the camera.
Agregar Comentario
Turn the camera so that the right side is facing you.
  • Turn the camera so that the right side is facing you.
  • Using your fingernail, gently pry up the clip holding the button panel in place along the side of the camera.
Agregar Comentario
Turn the camera so that the back side is facing you.
  • Turn the camera so that the back side is facing you.
  • Pry up this small clip with your fingernail.
  • The button panel will dislodge from the top of the camera allowing you to remove and replace it.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Ryan Bolton
Miembro Desde 23/01/11
301 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 11-27, Maness Winter 2011 Miembro de Cal Poly, Team 11-27, Maness Winter 2011
CPSU-MANESS-W11S11G27
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 895
