Introducción
This guide will instruct you how to remove the front and back covers from the camera and disassemble the flash in order to replace or repair it.
Qué necesitas
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
Press and hold down the button shown in the blue circle.
While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
Remove the one (1) screw from the top of the camera, on the left side of the flash (looking from the front) using a Phillips #00 screwdriver.
Lift the black plastic covering off the circuit board.
Remove the green circuit board from the top. Looking from the front of the camera, first lift the left side up above the black peg. The board should then slide out to the left.
3 personas más completaron esta guía.
2 comentarios
If it is the flash element that needs to be replace, I presume I will see it when I’m there.
Is this correct ?
effitech_structure@yahoo.com
