Introducción
Involving removal of the camera casing as well, this guide will help the user remove the LCD screen to repair or replace it.
Partes
No se requieren partes.
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
  • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
  • While still holding the switch, pull the cover down, allowing it to release and open.
Agregar Comentario
Tilt the camera slightly to allow the batteries to fall out.
  • Tilt the camera slightly to allow the batteries to fall out.
Agregar Comentario
Press on and release the memory card to eject it.
  • Press on and release the memory card to eject it.
Agregar Comentario
Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
  • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
  • Make sure to keep the different size screws organized to make reassembling the camera simpler.
Agregar Comentario
Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
Agregar Comentario
Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
Agregar Comentario
Remove the second battery cover on the bottom of camera. Take the silver battery out of the camera.
  • Remove the second battery cover on the bottom of camera.
  • Take the silver battery out of the camera.
Agregar Comentario
Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots. Remove the light grey, plastic piece. Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
  • Remove the light grey, plastic piece.
  • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
Agregar Comentario
Slightly pull on each side of the camera. It should loosen up and come apart. If it does not pull apart right away, use a little more force. Do not give up!
  • Slightly pull on each side of the camera. It should loosen up and come apart.
  • If it does not pull apart right away, use a little more force.
  • Do not give up!
Agregar Comentario
Remove the back case of the camera by pulling from the top.
  • Remove the back case of the camera by pulling from the top.
  • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
Agregar Comentario
Remove the 4mm Phillips #00 screw from above the ribbon.
  • Remove the 4mm Phillips #00 screw from above the ribbon.
Agregar Comentario
Gently peel off the blue tape on the top of the LCD screen.
  • Gently peel off the blue tape on the top of the LCD screen.
Agregar Comentario
Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
  • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
Agregar Comentario
Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
  • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
Agregar Comentario
Using a spudger, lift the grey tabs to allow the ribbon to slide out.
  • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
Agregar Comentario
Since the tabs have been lifted, the ribbon should now slide out out easily.
  • Since the tabs have been lifted, the ribbon should now slide out out easily.
  • Be careful not to distort the ribbon in any way.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Alex
Miembro Desde 18/01/13
67 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 19-42, Regan Winter 2013 Miembro de Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Miembros
6 Guías creadas
Thanks for this super documented guide.
I did it!! I found a second hand lcd on Ebay.
Now my camera is working again.
Super DIY guide!! Thanks a lot!!
Pierre - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 8
Todo El Tiempo: 884
