Start by removing the case in the previous guide. The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver. The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver.
  • Start by removing the case in the previous guide.
  • The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver.
Agregar Comentario
Once the spring is clear of the plastic, you can easily push the dowel through with a pin, the end of the tweezers, or a paperclip. Grab the dowel from the other end and pull it out. Grab the dowel from the other end and pull it out.
  • Once the spring is clear of the plastic, you can easily push the dowel through with a pin, the end of the tweezers, or a paperclip.
  • Grab the dowel from the other end and pull it out.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Biff Wheeler
Miembro Desde 06/06/12
738 Reputación
4 Guías creadas
Hi I have the camera of same model A1000.
Where can I get the battery cover, mine is broken?
Please share the details.
Chennakeshava Reddy Palla - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 7
Últimos 30 Días: 19
Todo El Tiempo: 2,333
