Introducción
This guide will show how to install a new scanner cover.
Herramientas
No se requieren herramientas.
Open the scanner cover, as if you are going to scan a document.
  • Open the scanner cover, as if you are going to scan a document.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pull the scanner cover straight up and it will come off.
  • Pull the scanner cover straight up and it will come off.
    • A quick and firm pull works best.
Agregar Comentario
Completely remove the scanner cover by peeling the thin white plastic sheet off. Completely remove the scanner cover by peeling the thin white plastic sheet off.
  • Completely remove the scanner cover by peeling the thin white plastic sheet off.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 19-41, Regan Winter 2013 Miembro de Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 8
Todo El Tiempo: 1,048
