Saltar al contenido principal
Canon Pixma MP480 Buttons Replacement
Qué necesitas
  1. Canon Pixma MP480 Buttons Replacement, Rear and Side Panel: paso 1, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement, Rear and Side Panel: paso 1, imagen 2 de 2
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Canon Pixma MP480 Buttons Replacement: paso 2, imagen 1 de 1
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Canon Pixma MP480 Buttons Replacement: paso 3, imagen 1 de 1
    • Open the front tray.
  4. Canon Pixma MP480 Buttons Replacement: paso 4, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement: paso 4, imagen 2 de 2
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Canon Pixma MP480 Buttons Replacement: paso 5, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement: paso 5, imagen 2 de 2
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Canon Pixma MP480 Buttons Replacement: paso 6, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement: paso 6, imagen 2 de 2
    • Pry open the side cover with the plastic opening tool.
  7. Canon Pixma MP480 Buttons Replacement: paso 7, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement: paso 7, imagen 2 de 2
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Canon Pixma MP480 Buttons Replacement: paso 8, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement: paso 8, imagen 2 de 2
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
  9. Canon Pixma MP480 Buttons Replacement, LCD: paso 9, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement, LCD: paso 9, imagen 2 de 2
    • Using the plastic opening tool, pry off the top cover of the LCD assembly.
    • Pry around the front and side edges for the easiest removal.
  10. Canon Pixma MP480 Buttons Replacement: paso 10, imagen 1 de 1
    • After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
  11. Canon Pixma MP480 Buttons Replacement: paso 11, imagen 1 de 1
    • Gently pull the ribbon cable to remove the LCD completely.
  12. Canon Pixma MP480 Buttons Replacement, Buttons: paso 12, imagen 1 de 1
    • Locate the buttons on the top of the printer.
  13. Canon Pixma MP480 Buttons Replacement: paso 13, imagen 1 de 1
    • Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
  14. Canon Pixma MP480 Buttons Replacement: paso 14, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement: paso 14, imagen 2 de 2
    • Remove the five 7.7 mm screws using a Phillips #1 screwdriver.
  15. Canon Pixma MP480 Buttons Replacement: paso 15, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement: paso 15, imagen 2 de 2
    • Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
  16. Canon Pixma MP480 Buttons Replacement: paso 16, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement: paso 16, imagen 2 de 2
    • Remove the two 7.8 mm screws using a Phillips #1 screwdriver.
  17. Canon Pixma MP480 Buttons Replacement: paso 17, imagen 1 de 1
    • Gently pull the LCD screen up to remove it from its fixture.
  18. Canon Pixma MP480 Buttons Replacement: paso 18, imagen 1 de 1
    • Use the plastic opening tool to pry off the plastic button assembly.
  19. Canon Pixma MP480 Buttons Replacement: paso 19, imagen 1 de 1
    • Gently pull the plastic button assembly up to remove it.
    • The plastic button assembly has a ribbon cable connected on the bottom, so be careful pulling it.
  20. Canon Pixma MP480 Buttons Replacement: paso 20, imagen 1 de 1
    • Remove the ribbon cable connected to the backside of the plastic button assembly.
  21. Canon Pixma MP480 Buttons Replacement: paso 21, imagen 1 de 2 Canon Pixma MP480 Buttons Replacement: paso 21, imagen 2 de 2
    • Remove the seven 8.7 mm screws using the Phillips #1 screwdriver.
  22. Canon Pixma MP480 Buttons Replacement: paso 22, imagen 1 de 3 Canon Pixma MP480 Buttons Replacement: paso 22, imagen 2 de 3 Canon Pixma MP480 Buttons Replacement: paso 22, imagen 3 de 3
    • Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
    • Gently lift the spring and pull the board out of its plastic button assembly.
  23. Canon Pixma MP480 Buttons Replacement: paso 23, imagen 1 de 1
    • Remove the buttons from the plastic button assembly.
Conclusión
Equipo
Cal Poly, Team 19-41, Regan Winter 2013 Miembro de Cal Poly, Team 19-41, Regan Winter 2013
CPSU-REGAN-W13S19G41
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,684
