Introducción
This guide tells you how to remove and repair or replace the LCD screen and the glass screen in your viewfinder.
Partes
No se requieren partes.
Orient the camera with the hand strap facing you.
  • Orient the camera with the hand strap facing you.
  • Remove the two 4mm #00 Philips screws.
  • When the screws are removed, the black plate will easily come off as well as the two metal plates under it. Be careful to not let them fall or get lost.
Agregar Comentario
Lift the strap up.
  • Lift the strap up.
Agregar Comentario
Orient the camera so that the back button panel and viewfinder are facing you.
  • Orient the camera so that the back button panel and viewfinder are facing you.
  • Push the "Battery Release" button to the side and hold.
Agregar Comentario
While holding the battery release button to the side, slide the battery towards you, past the release button.
  • While holding the battery release button to the side, slide the battery towards you, past the release button.
Agregar Comentario
Reorient camera so that the playback button panel and empty battery slot are facing you.  The edge of the LCD screen should be facing you.
  • Reorient camera so that the playback button panel and empty battery slot are facing you. The edge of the LCD screen should be facing you.
  • To open the screen, hold the open button shown down and flip the screen open.
  • Remove the two #00 Philips 4mm screws on the outer edge of the LCD casing.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Flip the screen counter-clockwise and reorient the camera with the bottom edge of the LCD screen facing you.
  • Flip the screen counter-clockwise and reorient the camera with the bottom edge of the LCD screen facing you.
  • Remove the 4mm #00 Phillips screw from the bottom of the LCD casing
Agregar Comentario
Remove the two 4mm #00 Phillips screws on the inside edge of the LCD casing. After removing the first screw you will have to rotate the screen 180 degrees to remove the second screw.
  • Remove the two 4mm #00 Phillips screws on the inside edge of the LCD casing. After removing the first screw you will have to rotate the screen 180 degrees to remove the second screw.
Agregar Comentario
Reorient the camera with the LCD screen edge and playback button panel facing you. Remove front panel of LCD screen by pulling it directly to the side.
  • Reorient the camera with the LCD screen edge and playback button panel facing you.
  • Remove front panel of LCD screen by pulling it directly to the side.
Agregar Comentario
Disconnect the screen components from the main body of the camcorder by applying downward pressure near the circled hinge.
  • Disconnect the screen components from the main body of the camcorder by applying downward pressure near the circled hinge.
Agregar Comentario
Remove the 4mm #00 Phillips screw connecting the LCD to the glass screen and lower casing.
  • Remove the 4mm #00 Phillips screw connecting the LCD to the glass screen and lower casing.
Agregar Comentario
Remove the lower casing by pushing up on the glass screen with your thumb. Remove the lower casing by pushing up on the glass screen with your thumb.
  • Remove the lower casing by pushing up on the glass screen with your thumb.
Agregar Comentario
Remove the glass screen from the LCD by lifting up on the cream colored hinge to disconnect the ribbon wire. Pull the glass screen away. Replace the glass screen if it is cracked or damaged.
  • Remove the glass screen from the LCD by lifting up on the cream colored hinge to disconnect the ribbon wire. Pull the glass screen away.
  • Replace the glass screen if it is cracked or damaged.
Agregar Comentario
Remove the LCD by disconnecting the remaining two ribbon wires by lifting up the cream-colored gate and sliding the ribbon out of the black gate.
  • Remove the LCD by disconnecting the remaining two ribbon wires by lifting up the cream-colored gate and sliding the ribbon out of the black gate.
Agregar Comentario
Replace the broken LCD with a new one.
  • Replace the broken LCD with a new one.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 1-12, Amido Winter 2011 Miembro de Cal Poly, Team 1-12, Amido Winter 2011
CPSU-AMIDO-W11S1G12
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,397
