Introducción
Use this guide to replace the grip of the camera.
Partes
No se requieren partes.
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
Agregar Comentario
On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
  • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
  • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
Agregar Comentario
Remove three medium length screws from the bottom of the camera
  • Remove three medium length screws from the bottom of the camera
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the two medium length screws on the front panel of the camera above the lens mount.
  • Remove the two medium length screws on the front panel of the camera above the lens mount.
  • Once you done, you may use the Spudger to panel from non-grip side.
  • If you start on the grip side, it will be more challenging to loosen the panel.
Agregar Comentario
Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
Agregar Comentario
Use your fingertip to pry off the external shutter port cover.
  • Use your fingertip to pry off the external shutter port cover.
Agregar Comentario
Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
Agregar Comentario
Use the spudger tool to carefully pry the grip from the rest of the camera. Use the spudger tool to carefully pry the grip from the rest of the camera. Use the spudger tool to carefully pry the grip from the rest of the camera.
  • Use the spudger tool to carefully pry the grip from the rest of the camera.
Agregar Comentario
Once the grip is loose, use your fingers to remove it from the camera.
  • Once the grip is loose, use your fingers to remove it from the camera.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Daniel Bussone
Miembro Desde 28/01/11
1,206 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 3-41, Regan Winter 2011 Miembro de Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Miembros
11 Guías creadas
Little confused. Some pics are from a analog Canon, other from a digital Canon...
Gustavo Aguiar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 2
Últimos 30 Días: 11
Todo El Tiempo: 2,898
