Saltar al contenido principal
Canon EOS Rebel G Grip Replacement
Qué necesitas
  1. Canon EOS Rebel G Grip Replacement, Front Panel: paso 1, imagen 1 de 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Grip Replacement: paso 2, imagen 1 de 2 Canon EOS Rebel G Grip Replacement: paso 2, imagen 2 de 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Grip Replacement: paso 3, imagen 1 de 3 Canon EOS Rebel G Grip Replacement: paso 3, imagen 2 de 3 Canon EOS Rebel G Grip Replacement: paso 3, imagen 3 de 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Grip Replacement, Grip: paso 4, imagen 1 de 1
    • Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
  5. Canon EOS Rebel G Grip Replacement: paso 5, imagen 1 de 1
    • Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
    • Use your fingers to pull out the plug that is located between the screw holes.
  6. Canon EOS Rebel G Grip Replacement: paso 6, imagen 1 de 2 Canon EOS Rebel G Grip Replacement: paso 6, imagen 2 de 2
    • Use the flat end of a spudger to pop the grip off and remove grip.
Conclusión
Una persona más ha completado esta guía.
Kyle Reis
Miembro Desde 04/02/12
52 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 14-9, Forte Spring 2012 Miembro de Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Miembros
36 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 1,555
