Saltar al contenido principal
Canon EOS 30 Top Panel Replacement
Qué necesitas
  1. Canon EOS 30 Top Panel Replacement, Front Panel: paso 1, imagen 1 de 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Top Panel Replacement: paso 2, imagen 1 de 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Top Panel Replacement: paso 3, imagen 1 de 1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Top Panel Replacement: paso 4, imagen 1 de 1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 Top Panel Replacement, Top Panel: paso 5, imagen 1 de 1
    • Slide the outer eyepiece upward to remove it.
  6. Canon EOS 30 Top Panel Replacement: paso 6, imagen 1 de 1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  7. Canon EOS 30 Top Panel Replacement: paso 7, imagen 1 de 1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  8. Canon EOS 30 Top Panel Replacement: paso 8, imagen 1 de 2 Canon EOS 30 Top Panel Replacement: paso 8, imagen 2 de 2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 8-8, Regan Spring 2011 Miembro de Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 2,713
