Introducción
Removing the front panel is the first step to accessing many internal components. Removal is safe, simple, and only requires a screwdriver.
Remove the two 4.8 mm black screws above the lens on the front of the camera.
  • Remove the two 4.8 mm black screws above the lens on the front of the camera.
Agregar Comentario
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the 4.8 mm black screw on the left side of the camera.
  • Remove the 4.8 mm black screw on the left side of the camera.
Agregar Comentario
Remove the front panel by lifting it away from the camera's body.
  • Remove the front panel by lifting it away from the camera's body.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 8-8, Regan Spring 2011 Miembro de Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 7
Todo El Tiempo: 1,810
