Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse
  • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse
my mouse sucks i peeled off the tape and there is a layer of something blocking the the screw it is a gaming mouse and i got it 2 weeks ago
Nathan Swercewski - Contestar
Use the Phillips #1 screwdriver to unscrew the six round head screws on the bottom of the mouse. Those marked with squares are 9 mm in length, the rest are 5 mm in length. Use the Phillips #1 screwdriver to unscrew the six round head screws on the bottom of the mouse. Those marked with squares are 9 mm in length, the rest are 5 mm in length.
  • Use the Phillips #1 screwdriver to unscrew the six round head screws on the bottom of the mouse. Those marked with squares are 9 mm in length, the rest are 5 mm in length.
Agregar Comentario
Grab the top shell of the mouse and lift up to remove. Grab the top shell of the mouse and lift up to remove. Grab the top shell of the mouse and lift up to remove.
  • Grab the top shell of the mouse and lift up to remove.
Agregar Comentario
The capacitors on this board can release stored electrical energy if touched.
  • The capacitors on this board can release stored electrical energy if touched.
  • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
To remove the white wire connector on the bottom board, use a spudger underneath the white plug and pop it out (this disconnects the upper board from the lower board). To remove the white wire connector on the bottom board, use a spudger underneath the white plug and pop it out (this disconnects the upper board from the lower board).
  • To remove the white wire connector on the bottom board, use a spudger underneath the white plug and pop it out (this disconnects the upper board from the lower board).
Agregar Comentario
Locate the 5 mm silver flat head mounting screws (2) to the left and right of the scroll wheel and remove with the Phillips #1 screwdriver. Locate the 5 mm silver flat head mounting screws (2) to the left and right of the scroll wheel and remove with the Phillips #1 screwdriver.
  • Locate the 5 mm silver flat head mounting screws (2) to the left and right of the scroll wheel and remove with the Phillips #1 screwdriver.
Agregar Comentario
Locate the snaps on the bottom corners of the mouse side panels and pop the indicated snaps out, using a spudger or your fingernail. Locate the snaps on the bottom corners of the mouse side panels and pop the indicated snaps out, using a spudger or your fingernail.
  • Locate the snaps on the bottom corners of the mouse side panels and pop the indicated snaps out, using a spudger or your fingernail.
Agregar Comentario
Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse. Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse. Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse.
  • Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse.
Agregar Comentario
Grab the sides of the mouse and lift them up to detach from the base of the mouse. Grab the sides of the mouse and lift them up to detach from the base of the mouse.
  • Grab the sides of the mouse and lift them up to detach from the base of the mouse.
Agregar Comentario
Pop the scroll wheel out of the snap holding it in place. You can use your finger or a spudger to do so. Pop the scroll wheel out of the snap holding it in place. You can use your finger or a spudger to do so.
  • Pop the scroll wheel out of the snap holding it in place. You can use your finger or a spudger to do so.
Agregar Comentario
Locate the four 5 mm black flat head screws on the corners of the bottom board. Unscrew these four black screws.
  • Locate the four 5 mm black flat head screws on the corners of the bottom board.
  • Unscrew these four black screws.
Agregar Comentario
Lift the bottom board up to remove from its mounting posts. This will separate it completely from the bottom panel of the mouse. Lift the bottom board up to remove from its mounting posts. This will separate it completely from the bottom panel of the mouse. Lift the bottom board up to remove from its mounting posts. This will separate it completely from the bottom panel of the mouse.
  • Lift the bottom board up to remove from its mounting posts. This will separate it completely from the bottom panel of the mouse.
Agregar Comentario
Conclusión
royceeklund
Miembro Desde 18/01/13
16 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 18-36, Regan Winter 2013 Miembro de Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 15
Últimos 30 Días: 65
Todo El Tiempo: 2,658
