Saltar al contenido principal
Bose Soundlink III Battery Replacement
Qué necesitas
  1. Bose Soundlink III Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
    • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
  2. Bose Soundlink III Battery Replacement: paso 2, imagen 1 de 2 Bose Soundlink III Battery Replacement: paso 2, imagen 2 de 2
    • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
    • These screws may be difficult to remove. If necessary, use a lever for extra torque.
    • Remove the bottom panel.
  3. Bose Soundlink III Battery Replacement: paso 3, imagen 1 de 1
    • Flip the rear panel back to allow access to the SoundLink's battery.
  4. Bose Soundlink III Battery Replacement: paso 4, imagen 1 de 2 Bose Soundlink III Battery Replacement: paso 4, imagen 2 de 2
    • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
Conclusión
38 personas más completaron esta guía.
Dakoda Sanders
Miembro Desde 02/04/16
1,540 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 3-2, Wollert Spring 2016 Miembro de USF Tampa, Team 3-2, Wollert Spring 2016
USFT-WOLLERT-S16S3G2
4 Miembros
7 Guías creadas
25 comentarios
Hello, I wonder where I could buy a raplacement battery for my Bose Soundlink III. (I'm from Belgium)
Thanks for the response.
Gabriel Lohest - Contestar
Gabriel, ik heb Bose gecontacteerd en ze zeggen dat ze dat niet apart verkopen. Het enigste wat ik heb gevonden is dit:http://www.ecrater.com/p/25268626/batter...
Of als het nog onder garantie valt, gewoon terug opsturen.
Gabrial, I've contacted Bose and they say that they didn't sell them seperately. The only thing that I've found is this:http://www.ecrater.com/p/25268626/batter...
If it still falls under warranty, send the speaker back.
JJ Hu - Contestar
yea i'm also interested to buy bose soundlink 3 battery hurmmm where could i get it....
Admin Fluffy - Contestar
Yes please, where do you get replacement batteries (I'm from Australia and Bose here want to charge me $149 to remove and replace 4 screws!)
Bob Mandassa - Contestar
I want to buy also. I'm here in Saudi arabia dammam
alphamendoza5 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 94
Ultimos 30 días: 396
Todo El Tiempo: 58,140
