Introducción
Follow this guide to install the trackball in the Blackberry Pearl 8100.
Partes
No se requieren partes.
Before working on the phone, be sure that the phone is turned off. Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
  • Before working on the phone, be sure that the phone is turned off.
  • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
Agregar Comentario
  • Remove the battery located directly below back panel.
Agregar Comentario
Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
  • Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
Agregar Comentario
Using the spudger, pry off the small portion of the casing located at the bottom of the phone. Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
  • Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
  • Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
Agregar Comentario
Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
  • Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
Agregar Comentario
Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face.  Remove the back body panel. Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face.  Remove the back body panel.
  • Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
Agregar Comentario
Separate the logic board from the front panel.
  • Separate the logic board from the front panel.
Agregar Comentario
Gently remove the keyboard from front casing. It should snap out of place. Gently remove the keyboard from front casing. It should snap out of place.
  • Gently remove the keyboard from front casing. It should snap out of place.
Agregar Comentario
Remove the larger chrome ring holding the track ball in place by using the spudger to gently wedge the top ring away, approaching from the front face.
  • Remove the larger chrome ring holding the track ball in place by using the spudger to gently wedge the top ring away, approaching from the front face.
  • Some of these parts are fairly small and fragile; be sure to keep them in a safe place where they won't be damaged if you intend to reuse them.
Agregar Comentario
Remove the smaller chrome inner ring surrounding the trackball; it should be able to be simply lifted by hand.
  • Remove the smaller chrome inner ring surrounding the trackball; it should be able to be simply lifted by hand.
Agregar Comentario
Remove the trackball housing; it should be able to be removed by hand.
  • Remove the trackball housing; it should be able to be removed by hand.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Robert Cronin
Miembro Desde 08/04/10
520 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 34-57, Forte Spring 2010 Miembro de Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
5 Miembros
6 Guías creadas
why dissasemble the entire device, just remove the chrome ring....
Latios Eon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 7,482
