Turn the device upside down. Using your finger, slide the silver cover release button towards the top of the device.
  • Turn the device upside down.
  • Using your finger, slide the silver cover release button towards the top of the device.
  • Lift and remove the back cover.
Agregar Comentario
Using your fingernails, lift the sides of the battery.
  • Using your fingernails, lift the sides of the battery.
  • Remove the battery.
Agregar Comentario
Orient the device so the screen is facing the ground.
  • Orient the device so the screen is facing the ground.
  • Using your finger, gently lift the top of the SIM card.
Agregar Comentario
Gently pull out the SIM card.
  • Gently pull out the SIM card.
  • The card will break in half if you apply too much force when pulling out the card.
make sure to takeout memory card also.
Trying to open the back part with card still installed is a BIG NO NO.
ralph - Contestar
I ordered a new speaker and as soon as it came it I jumped on here to look at the directions. followed the directions exactly and now it works again. Only suggestion is to be careful removing ear piece cover, there are 4 small fragile plastic prongs at the top that can easily break. I broke 2 but phone still works! Thanks for the help!
Jeremiah Croych - Contestar
Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
  • Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
Agregar Comentario
Orient the device so that the screen is facing you.
  • Orient the device so that the screen is facing you.
  • Using a spudger, remove the ear piece cover.
Agregar Comentario
Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
  • Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
Agregar Comentario
Remove the back chassis by gently pulling the chassis back and forth.
  • Remove the back chassis by gently pulling the chassis back and forth.
  • The headphone jack can break if the chassis is pulled too forcefully.
Agregar Comentario
Orient the device so the screen is facing the ground and the top of phone is facing you.
  • Orient the device so the screen is facing the ground and the top of phone is facing you.
  • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
      • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
Agregar Comentario
Using your fingers, carefully lift and remove the mother board.
  • Using your fingers, carefully lift and remove the mother board.
  • The connectors underneath the mother board are delicate and easily damaged.
Agregar Comentario
Using a pair of tweezers, remove the three ribbon connectors.
  • Using a pair of tweezers, remove the three ribbon connectors.
  • The ribbon cable connectors are delicate and easily damaged.
Agregar Comentario
Remove the mother board by lifting the board upward.
  • Remove the mother board by lifting the board upward.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Ryan
Miembro Desde 12/03/12
615 Reputación
11 Guías creadas
Equipo
Clemson, Team 2-5, Benson Spring 2012 Miembro de Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 3
Todo El Tiempo: 3,560
