Introducción
This guide outlines how to do initial disassembly for the device and doubles as prerequisites for other guides.
Partes
No se requieren partes.
With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
Agregar Comentario
Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
Agregar Comentario
Remove the battery by pushing against it from the right and then pulling towards you.
  • Remove the battery by pushing against it from the right and then pulling towards you.
Agregar Comentario
Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
Agregar Comentario
Use a plastic opening tool or your fingernails to remove the plastic backing. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  • Use a plastic opening tool or your fingernails to remove the plastic backing.
  • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
Agregar Comentario
Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
  • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
  • Place the four screws released from the phone in a plastic bag.
Agregar Comentario
The black battery casing and logic board can now be separated for the following steps.
  • The black battery casing and logic board can now be separated for the following steps.
Agregar Comentario
Conclusión
kelogan
Miembro Desde 04/11/09
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-17, Regan Fall 2009 Miembro de Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 2,059
