Qué necesitas
Turn phone over to the backside.
Press down on the lower portion of the back cover.
Slide the lower portion down to remove the cover and reveal the battery.
Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
Disconnect the tab attached to the interior casing from the LCD Screen by gently pulling the tab up and away from the phone.
Use the Plastic Opening Tool to pry the LCD Screen out.
Una persona más ha completado esta guía.
