Introducción
To replace a damaged or malfunctioning screen, use this guide.
Qué necesitas
Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break.
Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
One is located below the scrollwheel.
Another is located behind the screen.
Pull out the two black clips securing the screen’s ribbon so that they are as far out as they will go.
Gently remove the screen’s ribbon from the slot. Be sure to support the screen and any connected parts.
