Introducción
Replacing a defective or faulty keyboard on a BlackBerry Curve 8900.
Partes
No se requieren partes.
Remove the back cover and battery.
  • Remove the back cover and battery.
Agregar Comentario
4 screws should be visible. Pry off lower portion of the back to reveal all 6 screws.
  • 4 screws should be visible. Pry off lower portion of the back to reveal all 6 screws.
Agregar Comentario
Remove all six T6 screws from the midframe.
  • Remove all six T6 screws from the midframe.
Agregar Comentario
Separate the midframe from the rest of the device.
  • Separate the midframe from the rest of the device.
Agregar Comentario
Gently pry the back the plastic tabs that secure the motherboard to the case.
  • Gently pry the back the plastic tabs that secure the motherboard to the case.
  • Slowly work your way around the case until the tabs until the motherboard comes free.
  • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
Agregar Comentario
Lift the keypad from the motherboard. When replacing the keypad, be sure that the navigation ball is in the original position. When replacing the keypad, be sure that the navigation ball is in the original position.
  • Lift the keypad from the motherboard.
  • When replacing the keypad, be sure that the navigation ball is in the original position.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Renae Bishop
Miembro Desde 07/09/11
66 Reputación
4 Guías creadas
Equipo
Cuesta, Team 1-3, Zipperian Fall 2011 Miembro de Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 6,581
