Partes
No se requieren partes.
Place the phone on a flat surface with the screen facing down. Remove the plastic backplate by pulling up on the bottom of the cover.
  • Place the phone on a flat surface with the screen facing down.
  • Remove the plastic backplate by pulling up on the bottom of the cover.
Agregar Comentario
Remove the battery by pulling up from the top of the battery.
  • Remove the battery by pulling up from the top of the battery.
Agregar Comentario
Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver. Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
  • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
  • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Flip the phone over so the keyboard faces up. Insert a plastic spudger into the screen where speaker resides.
  • Flip the phone over so the keyboard faces up.
  • Insert a plastic spudger into the screen where speaker resides.
  • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
  • Gently lift up plastic screen cover until screen cover separates from screen.
  • Continue until screen cover is completely removed.
Agregar Comentario
Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up. Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed. Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
  • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
  • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
Agregar Comentario
The keyboard should slide off of the phone now that the plastic siding has been removed. The keyboard should slide off of the phone now that the plastic siding has been removed.
  • The keyboard should slide off of the phone now that the plastic siding has been removed.
Agregar Comentario
To detach the screen, there are two screws at the top of the phone to be removed.  Use the T6 Torx Screwdriver to remove the screws. There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone. Note: When reassembling, the ribbon should be reattached before replacing the top screws.
  • To detach the screen, there are two screws at the top of the phone to be removed. Use the T6 Torx Screwdriver to remove the screws.
  • There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone.
    • Note: When reassembling, the ribbon should be reattached before replacing the top screws.
Agregar Comentario
There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen. Use pressure to unlatch the screen from the clips. Now that these clips have been undone, the screen should lift up easily.
  • There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen.
  • Use pressure to unlatch the screen from the clips.
  • Now that these clips have been undone, the screen should lift up easily.
Agregar Comentario
Linea de Meta
7 personas más completaron esta guía.
Equipo
Cal Poly, Team 15-13, Regan Spring 2011 Miembro de Cal Poly, Team 15-13, Regan Spring 2011
CPSU-REGAN-S11S15G13
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 6
Todo El Tiempo: 7,569
