Saltar al contenido principal
BlackBerry 8820 Motherboard Replacement
Qué necesitas
  1. BlackBerry 8820 Motherboard Replacement, Disassembling BlackBerry 8820 Outer Casing: paso 1, imagen 1 de 1
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. BlackBerry 8820 Motherboard Replacement: paso 2, imagen 1 de 2 BlackBerry 8820 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. BlackBerry 8820 Motherboard Replacement: paso 3, imagen 1 de 2 BlackBerry 8820 Motherboard Replacement: paso 3, imagen 2 de 2
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. BlackBerry 8820 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use a nylon spudger to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  5. BlackBerry 8820 Motherboard Replacement: paso 5, imagen 1 de 1
    • Pry off the front casing.
    • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  6. BlackBerry 8820 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 BlackBerry 8820 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
    • Remove the bottom casing clip, it will easily unsnap when pulled
  7. BlackBerry 8820 Motherboard Replacement: paso 7, imagen 1 de 2 BlackBerry 8820 Motherboard Replacement: paso 7, imagen 2 de 2
    • Unhook both sides of the white wire from the motherboard using the plastic opening tool from before
  8. BlackBerry 8820 Motherboard Replacement: paso 8, imagen 1 de 2 BlackBerry 8820 Motherboard Replacement: paso 8, imagen 2 de 2
    • At the top of the phone, locate the gloss SATA cable strap connecting the LCD screen to the phone.
    • Using the prying tool, unattach this cable by levering under the connector
    • When removing the ribbon cable handle with care; it is prone to breaking
  9. BlackBerry 8820 Motherboard Replacement: paso 9, imagen 1 de 2 BlackBerry 8820 Motherboard Replacement: paso 9, imagen 2 de 2
    • WARNING: Be sure to have disconnected the SATA cable strap prior to attempting this.
    • Using the prying tool, lever up the old screen as shown.
  10. BlackBerry 8820 Motherboard Replacement: paso 10, imagen 1 de 3 BlackBerry 8820 Motherboard Replacement: paso 10, imagen 2 de 3 BlackBerry 8820 Motherboard Replacement: paso 10, imagen 3 de 3
    • There will be two small clips on each side of the motherboard. Using the plastic opening tool unhook each clip one at a time
    • Once all four clips are unhooked you should be able to pull the motherboard from the casing using your hands.
    • After you remove the old motherboard, you can then replace it with a new one.
Conclusión
3 personas más completaron esta guía.
ryan
Miembro Desde 04/12/13
44 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-64, Johann Spring 2013 Miembro de Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 884
