Saltar al contenido principal
BlackBerry 8703e Battery Replacement
Qué necesitas
  1. BlackBerry 8703e Battery Replacement, Battery: paso 1, imagen 1 de 2 BlackBerry 8703e Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Position your phone like the first image so that the highlighted button is on your left.
    • Slide the battery cover to the left while pressing the button with one hand and applying pressure on the center of the phone with your other hand.
    • Remove the cover completely and set it aside.
  2. BlackBerry 8703e Battery Replacement: paso 2, imagen 1 de 1
    • Position your phone like the image to the left, then locate the rectangular battery in the middle of the phone.
    • Locate the notch on the top right of the battery compartment.
    • Slide your fingernail or the flat end of a Spudger in the notch, then lift upwards on the top of the battery to remove it from the phone.
    • Set the battery aside and out of the way.
Conclusión
Equipo
Cal Poly, Team 11-3, Forte Winter 2010 Miembro de Cal Poly, Team 11-3, Forte Winter 2010
CPSU-FORTE-W10S11G3
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 3,386
