Saltar al contenido principal
BlackBerry 8700c Replacing Logic Board Replacement
Qué necesitas
  1. BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: paso 1, imagen 1 de 2 BlackBerry 8700c Replacing Logic Board Replacement, Replacing Logic Board: paso 1, imagen 2 de 2
    • Remove the back cover by pushing down on the button and sliding the cover towards the bottom of the phone.
    • Set the cover aside. The battery will now be exposed.
  2. BlackBerry 8700c Replacing Logic Board Replacement: paso 2, imagen 1 de 2 BlackBerry 8700c Replacing Logic Board Replacement: paso 2, imagen 2 de 2
    • Remove the battery by pulling back on the notch on top edge of the battery.
    • Set the battery aside.
  3. BlackBerry 8700c Replacing Logic Board Replacement: paso 3, imagen 1 de 1
    • Unscrew and remove all four T6 Torx screws.
  4. BlackBerry 8700c Replacing Logic Board Replacement: paso 4, imagen 1 de 2 BlackBerry 8700c Replacing Logic Board Replacement: paso 4, imagen 2 de 2
    • Pull the back cover of the phone off and set it aside.
  5. BlackBerry 8700c Replacing Logic Board Replacement: paso 5, imagen 1 de 2 BlackBerry 8700c Replacing Logic Board Replacement: paso 5, imagen 2 de 2
    • Unscrew and remove all 4 T6 Torx screws.
  6. BlackBerry 8700c Replacing Logic Board Replacement: paso 6, imagen 1 de 3 BlackBerry 8700c Replacing Logic Board Replacement: paso 6, imagen 2 de 3 BlackBerry 8700c Replacing Logic Board Replacement: paso 6, imagen 3 de 3
    • Lift and remove inner back cover and set aside.
    • A small side piece may fall away but is simple to reattach.
    • Remove logic board by gently lifting it off of the front cover of the phone.
    • New logic board can now simply be set in place.
Conclusión
arlebrun
Miembro Desde 12/02/09
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-4, Maness Fall 2009 Miembro de Cal Poly, Team 18-4, Maness Fall 2009
CPSU-MANESS-F09S18G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 3,240
