Introducción
This guide will instruct on how to extract the antenna from the RIM Blackberry 7510 and replace it with a new one.
Partes
No se requieren partes.
Unscrew all six visible screws.
  • Unscrew all six visible screws.
Agregar Comentario
Pry open back plate using spudger. Pry open back plate using spudger.
  • Pry open back plate using spudger.
Agregar Comentario
Unscrew antenna from back cover.
  • Unscrew antenna from back cover.
Agregar Comentario
The bad antenna is now removed and may be replaced.
  • The bad antenna is now removed and may be replaced.
Agregar Comentario
Conclusión
Neil Johnson
Miembro Desde 24/01/10
12 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-44, Regan Winter 2010 Miembro de Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,738
