Introducción
Use this guide to replace the motherboard on your RIM BlackBerry 7290.
With your index finger, press down on the lock button to unlock the battery cover. Slide the battery cover down towards you to reveal the battery. Slide the battery cover down towards you to reveal the battery.
  • With your index finger, press down on the lock button to unlock the battery cover.
  • Slide the battery cover down towards you to reveal the battery.
Agregar Comentario
Use your index finger to lift and remove the battery from the phone. Use your index finger to lift and remove the battery from the phone. Use your index finger to lift and remove the battery from the phone.
  • Use your index finger to lift and remove the battery from the phone.
Agregar Comentario
Slide the SIM card holder to the left to unlock the SIM card.
  • Slide the SIM card holder to the left to unlock the SIM card.
Agregar Comentario
Lift the SIM card holder up. Gently remove the SIM card from the SIM card holder.
  • Lift the SIM card holder up.
  • Gently remove the SIM card from the SIM card holder.
Agregar Comentario
Remove the four top screws using a T-6 torx screwdriver.
  • Remove the four top screws using a T-6 torx screwdriver.
  • The top four screws are .413 inches.
Agregar Comentario
Remove the two bottom screws using a T-6 torx screwdriver. The bottom two screws are .2 inches in length.
  • Remove the two bottom screws using a T-6 torx screwdriver.
  • The bottom two screws are .2 inches in length.
  • The second picture displays the device after the six screws have been removed.
Agregar Comentario
Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
Agregar Comentario
With both of the bottom clips unhooked, lift the bottom portion of the phone and slide it upwards (towards your fingers) to detach the back cover from the front cover. With both of the bottom clips unhooked, lift the bottom portion of the phone and slide it upwards (towards your fingers) to detach the back cover from the front cover. With both of the bottom clips unhooked, lift the bottom portion of the phone and slide it upwards (towards your fingers) to detach the back cover from the front cover.
  • With both of the bottom clips unhooked, lift the bottom portion of the phone and slide it upwards (towards your fingers) to detach the back cover from the front cover.
Agregar Comentario
Using a T-6 screwdriver, remove the screw located on top of the phone. After the screw has been removed, carefully lift the side button brace to reveal the side button.
  • Using a T-6 screwdriver, remove the screw located on top of the phone.
  • After the screw has been removed, carefully lift the side button brace to reveal the side button.
Agregar Comentario
To remove the logic board mounting plate, start by loosening one side of the phone.
  • To remove the logic board mounting plate, start by loosening one side of the phone.
Agregar Comentario
With one side loosened, simply lift the logic board mounting plate off of the phone's front cover.
  • With one side loosened, simply lift the logic board mounting plate off of the phone's front cover.
Agregar Comentario
Turn the logic board mounting plate over to reveal the LCD display.
  • Turn the logic board mounting plate over to reveal the LCD display.
Agregar Comentario
Peel off the rubber keypad buttons from the face plate. Peel off the rubber keypad buttons from the face plate.
  • Peel off the rubber keypad buttons from the face plate.
Agregar Comentario
Use a plastic opening tool to unhook the LCD display from the logic board mounting plate.
  • Use a plastic opening tool to unhook the LCD display from the logic board mounting plate.
Agregar Comentario
With the clip unhooked, gently pull off the LCD display from the phone. With the clip unhooked, gently pull off the LCD display from the phone.
  • With the clip unhooked, gently pull off the LCD display from the phone.
Agregar Comentario
Remove the the three screws that are highlighted in red using a T6 torx screwdriver. The screw is .2 inches in length.
  • Remove the the three screws that are highlighted in red using a T6 torx screwdriver.
  • The screw is .2 inches in length.
Agregar Comentario
Remove the screw using a T6 torx screwdriver
  • Remove the screw using a T6 torx screwdriver
Agregar Comentario
Separate the logic board mounting plate from the logic board. Separate the logic board mounting plate from the logic board.
  • Separate the logic board mounting plate from the logic board.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
kmathew
Miembro Desde 17/10/09
3 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 19-6, Maness Fall 2009 Miembro de Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 Miembros
7 Guías creadas
hi wonder if you can help or give me advice on my device. its not turning on looks like it turns on with the hour glass turning but nothing happens
douwmg - Contestar
my device doesn't want to switch on its just the hour glass on the screen that turns on the screen but its not turning on?
douwmg - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 4,696
