Introducción
The inner keyboard is the internal part of the device's keyboard. This part provides connections between the rubber keys and the device's motherboard. This guide demonstrates how to remove the inner keyboard after removing the outer case.
Partes
No se requieren partes.
With your thumb press down on the locking- button on the back of the BlackBerry 7280. Slide the battery cover off the device. Slide the battery cover off the device.
  • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
  • Slide the battery cover off the device.
Agregar Comentario
Remove the lithium-ion battery from the back of the device using your index finger. Remove the lithium-ion battery from the back of the device using your index finger.
  • Remove the lithium-ion battery from the back of the device using your index finger.
Agregar Comentario
Hold the device with both hands. Lift the SIM card holder using your thumb and index finger. Remove the SIM card from the device.
  • Hold the device with both hands.
  • Lift the SIM card holder using your thumb and index finger.
  • Remove the SIM card from the device.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside. The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
  • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
Agregar Comentario
Use the plastic opening tool to pry the back case away from the front case. Use the plastic opening tool to pry the back case away from the front case.
  • Use the plastic opening tool to pry the back case away from the front case.
Agregar Comentario
Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket.  Set aside the screw and the bracket. Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket.  Set aside the screw and the bracket.
  • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
Agregar Comentario
Remove the front plastic case from the metal bracket. Remove the front plastic case from the metal bracket.
  • Remove the front plastic case from the metal bracket.
Agregar Comentario
To remove the inner keyboard, simply peel it off of the logic board as shown.
  • To remove the inner keyboard, simply peel it off of the logic board as shown.
Agregar Comentario
Conclusión
Equipo
Clemson, Team 12-2, Benson Spring 2013 Miembro de Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 200
