Introducción
How to replace the battery
Herramientas
No se requieren herramientas.
Partes
Turn the phone over so that the screen is facing the work surface
  • Turn the phone over so that the screen is facing the work surface
Agregar Comentario
Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
  • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
  • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
Agregar Comentario
Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
  • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
Agregar Comentario
Conclusión
Sean Tiernan
Miembro Desde 20/01/10
5 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-16, Maness Winter 2010 Miembro de Cal Poly, Team 3-16, Maness Winter 2010
CPSU-MANESS-W10S3G16
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,810
