Saltar al contenido principal
BlackBerry 7100g Keypad Cover Replacement
Qué necesitas
  1. BlackBerry 7100g Keypad Cover Replacement, Battery: paso 1, imagen 1 de 1
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Keypad Cover Replacement: paso 2, imagen 1 de 3 BlackBerry 7100g Keypad Cover Replacement: paso 2, imagen 2 de 3 BlackBerry 7100g Keypad Cover Replacement: paso 2, imagen 3 de 3
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Keypad Cover Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Keypad Cover Replacement, Housing: paso 4, imagen 1 de 3 BlackBerry 7100g Keypad Cover Replacement, Housing: paso 4, imagen 2 de 3 BlackBerry 7100g Keypad Cover Replacement, Housing: paso 4, imagen 3 de 3
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Keypad Cover Replacement: paso 5, imagen 1 de 2 BlackBerry 7100g Keypad Cover Replacement: paso 5, imagen 2 de 2
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Keypad Cover Replacement: paso 6, imagen 1 de 3 BlackBerry 7100g Keypad Cover Replacement: paso 6, imagen 2 de 3 BlackBerry 7100g Keypad Cover Replacement: paso 6, imagen 3 de 3
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Keypad Cover Replacement: paso 7, imagen 1 de 1
    • You can now easily remove the "guts" of the phone from the housing.
  8. BlackBerry 7100g Keypad Cover Replacement, Keypad Cover: paso 8, imagen 1 de 2 BlackBerry 7100g Keypad Cover Replacement, Keypad Cover: paso 8, imagen 2 de 2
    • Remove the keypad cover.
    • Insert the new keypad cover.
    • You are done replacing your keypad cover.
Conclusión
Tristan French
Miembro Desde 04/04/10
34 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 25-87, Amido Spring 2010 Miembro de Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 1,448
