Introducción
This guide shows how to replace the BlackBerry 7100g external housing case.
Turn over your BalckBerry 7100g so that the back cover is facing up.
  • Turn over your BalckBerry 7100g so that the back cover is facing up.
  • Locate the battery cover release button near the bottom of the back panel.
Agregar Comentario
Push down on the release button with one thumb. Slide the battery cover off with the other thumb. Slide the battery cover off with the other thumb.
  • Push down on the release button with one thumb.
  • Slide the battery cover off with the other thumb.
Agregar Comentario
Remove the battery from the battery housing by flipping up the top of the battery.
  • Remove the battery from the battery housing by flipping up the top of the battery.
Agregar Comentario
Locate the silver strip near the top of your BlackBerry. Use a plastic opening tool to pry off the edge of the silver lining. Slide the tool along the length of the silver strip to completely remove it.
  • Locate the silver strip near the top of your BlackBerry.
  • Use a plastic opening tool to pry off the edge of the silver lining.
  • Slide the tool along the length of the silver strip to completely remove it.
Agregar Comentario
Do not lose the screws. They are quite small and can easily be misplaced. Locate and unscrew the four (4) screws using a T6 screwdriver.
  • Do not lose the screws. They are quite small and can easily be misplaced.
  • Locate and unscrew the four (4) screws using a T6 screwdriver.
Agregar Comentario
The keypad cover may fall out of the housing when prying the housing apart. Tightly pinch the top of the front and back halves of the housing. Carefully pry the two halves of the housing apart.
  • The keypad cover may fall out of the housing when prying the housing apart.
  • Tightly pinch the top of the front and back halves of the housing.
  • Carefully pry the two halves of the housing apart.
Agregar Comentario
You can now easily remove the "guts" of the phone from the housing.
  • You can now easily remove the "guts" of the phone from the housing.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Kellen
Miembro Desde 30/03/10
262 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 25-87, Amido Spring 2010 Miembro de Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,119
