Saltar al contenido principal
Belling Synergie Oven Technique
  1. Belling Synergie Oven Technique, Belling Synergie Oven Technique: paso 1, imagen 1 de 1
    • Hold down either the first or first two buttons (depending on the model).
    • Use the arrow buttons to set the clock (It always starts at 12:00).
Conclusión
6 personas más completaron esta guía.
Peter Neal
Miembro Desde 02/06/11
186 Reputación
1 Guía escrita
3 comentarios
What if the buttons stopped working? I can’t press them down.
Elizabeth Robertson - Contestar
Update:
I can press them down like I normally can but the clock won’t change and the time stays as it is. I can only use the top oven.
Something that worked with my Blomberg and may help is to turn off the power to the oven, wait 10 seconds and then turn the power back on - the oven then behaves as though it is being newly installed, the clock resets to 12.00, and should be re-settable. Good luck
Howard Morgan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 108
Todo El Tiempo: 18,858
