Introducción
The ball bearings reduce the friction caused by the rotating wheel by concentrating it on rolling bearings, in this case there are ten on each side of the axle. Well maintained ball bearings will help the wheel spin more freely and allow for an easier and smoother ride.
Notes:
  • When cleaning the bearings and cones, solvents like kerosene can be very effective, however, just a wipe down with a rag is sufficient.
  • When the wheel is assembles correctly there should be very little resistance between the axle and the wheel and each should spin freely of the other.
  • Some of these steps require near-perfect alignment. They may take several tries to get right, so patience is a must.
Herramientas
Partes
No se requieren partes.
Flip the quick release lever on the wheel. Flip the quick release lever on the wheel.
  • Flip the quick release lever on the wheel.
Agregar Comentario
Squeeze the brake arms together and lift the brake cable from the caliper arms.
  • Squeeze the brake arms together and lift the brake cable from the caliper arms.
Agregar Comentario
Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
Agregar Comentario
Unscrew the quick release nut from the quick release axle. Remove the quick release axle. After removing the axle you should notice that there are two springs on it. Be careful not to lose these. After removing the axle you should notice that there are two springs on it. Be careful not to lose these.
  • Unscrew the quick release nut from the quick release axle. Remove the quick release axle.
  • After removing the axle you should notice that there are two springs on it. Be careful not to lose these.
Agregar Comentario
Fit the cone wrench to the cone, and fit the open end wrench to the top lock nut. Hold the cone in place with the cone wrench and turn the open end wrench to loosen and remove the top lock nut. Keep track of which side each lock nut goes on. The order is important because the threading for each nut is specific for each side.
  • Fit the cone wrench to the cone, and fit the open end wrench to the top lock nut. Hold the cone in place with the cone wrench and turn the open end wrench to loosen and remove the top lock nut.
  • Keep track of which side each lock nut goes on. The order is important because the threading for each nut is specific for each side.
Agregar Comentario
Unscrew the cone, and set it aside. Keep track of which side each cone goes on. The order is important because the threading for each cone is specific for each side.
  • Unscrew the cone, and set it aside.
  • Keep track of which side each cone goes on. The order is important because the threading for each cone is specific for each side.
Agregar Comentario
Remove the axle and all ball bearings. Caution: There are 10 ball bearings on each side, be careful not to lose any if you plan on putting the old ones back in!
  • Remove the axle and all ball bearings.
  • Caution: There are 10 ball bearings on each side, be careful not to lose any if you plan on putting the old ones back in!
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Inspect cone surfaces and all ball bearings for dents, cracks or blemishes. If any are damaged,  replace them. If any are damaged,  replace them.
  • Inspect cone surfaces and all ball bearings for dents, cracks or blemishes.
  • If any are damaged, replace them.
Agregar Comentario
Clean bearings, the bearing races, and cones by wiping them off with a rag.
  • Clean bearings, the bearing races, and cones by wiping them off with a rag.
Agregar Comentario
Liberally apply grease to the bearings, races, and cones. Liberally apply grease to the bearings, races, and cones.
  • Liberally apply grease to the bearings, races, and cones.
Agregar Comentario
Insert the axle back into the wheel, with the still attached nut and cone on the bottom side of the wheel.
  • Insert the axle back into the wheel, with the still attached nut and cone on the bottom side of the wheel.
Agregar Comentario
Insert 10 bearings into the topmost bearing races.
  • Insert 10 bearings into the topmost bearing races.
  • Make sure that you insert exactly 10. If you insert too many or too few, it can damage the bearings.
Agregar Comentario
Carefully drop the axle out from the bottom of the wheel. Re-insert the axle from the top side of the wheel, so that the attached nut and bearing and cone set are now sticking out of the top.
  • Carefully drop the axle out from the bottom of the wheel.
  • Re-insert the axle from the top side of the wheel, so that the attached nut and bearing and cone set are now sticking out of the top.
  • Now flip the wheel upside down.
Agregar Comentario
Insert the remaining 10 bearings into the bearing races on the opposite side.
  • Insert the remaining 10 bearings into the bearing races on the opposite side.
  • Caution: make sure you insert exactly 10 bearings into each bearing race.
Agregar Comentario
Hand tighten bearing cone onto the free end of the axle, so that it touches the bearings without putting any pressure on them. Ideally, there should be no movement or give in the axle when you pull on it or try to wiggle it. Additionally, the axle should be able to spin freely in the wheel, with minimal resistance.
  • Hand tighten bearing cone onto the free end of the axle, so that it touches the bearings without putting any pressure on them.
  • Ideally, there should be no movement or give in the axle when you pull on it or try to wiggle it. Additionally, the axle should be able to spin freely in the wheel, with minimal resistance.
Agregar Comentario
Slide the washer onto the axle. Hand tighten the lock nut against the cone and washer.
  • Slide the washer onto the axle.
  • Hand tighten the lock nut against the cone and washer.
Agregar Comentario
Once in proper position, use the cone wrench and open wrench to tighten the lock nut.
  • Once in proper position, use the cone wrench and open wrench to tighten the lock nut.
  • Tighten the lock nut VERY tightly. Otherwise the wheel can come out of alignment while you are riding.
Agregar Comentario
Check the way that the axle spins in the wheel. The action should be smooth, with virtually no slop when wiggled. If it is to tight or too sloppy then you need to repeat the previous step.
  • Check the way that the axle spins in the wheel. The action should be smooth, with virtually no slop when wiggled. If it is to tight or too sloppy then you need to repeat the previous step.
Agregar Comentario
Reinsert the quick release axle, and put the wheel back on the bike. The springs should have the smaller tapered end closest to the hub The springs should have the smaller tapered end closest to the hub
  • Reinsert the quick release axle, and put the wheel back on the bike.
  • The springs should have the smaller tapered end closest to the hub
Agregar Comentario
Linea de Meta
2 personas más completaron esta guía.
Tyler Parra
Miembro Desde 10/10/10
397 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 5-13, Maness Fall 2010 Miembro de Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Miembros
11 Guías creadas
Display and text were really helpful. I was wondering what happened to the sprocket assembly. from steps 1 through 3. This worked fine for the front wheel when I did it, but I'm not sure about working on the rear wheel. Does the sprocket assembly stay on the axle when you take off the lock nut and cone from the other side? Thanks Bob
Bob Walsh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 15
Últimos 30 Días: 104
Todo El Tiempo: 14,611
