Partes
No se requieren partes.
Locate the antenna (shown in red box) at the top of the phone when closed.
  • Locate the antenna (shown in red box) at the top of the phone when closed.
Agregar Comentario
Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise.  Once loose, remove the antenna by pulling it from its insert hole.
  • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
Agregar Comentario
Locate the back side of the phone.
  • Locate the back side of the phone.
  • The battery is the large main compartment (red box).
Agregar Comentario
Use your finger to slide the latch (circled) upwards.
  • Use your finger to slide the latch (circled) upwards.
  • While holding the latch up, pull the battery off the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
The back of the phone will look like this when the battery is correctly removed.
  • The back of the phone will look like this when the battery is correctly removed.
Agregar Comentario
Peel the rubber indicated toward the top of the phone
  • Peel the rubber indicated toward the top of the phone
Agregar Comentario
Remove the screw that sits underneath the rubber covering.
  • Remove the screw that sits underneath the rubber covering.
Agregar Comentario
Remove the five (5) total screws using a Philips head screwdriver.
  • Remove the five (5) total screws using a Philips head screwdriver.
Agregar Comentario
Use spudger and insert it towards the bottom of the phone as pictured.
  • Use spudger and insert it towards the bottom of the phone as pictured.
  • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
  • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
Agregar Comentario
The back case should now be completely removed and the motherboard will be visible.
  • The back case should now be completely removed and the motherboard will be visible.
Agregar Comentario
Conclusión
Carlos Guerrero
Miembro Desde 04/10/10
1 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 3-24, Regan Fall 2010 Miembro de Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,559
