Saltar al contenido principal
Audiovox CDM-8910 LCD Screen Replacement
Qué necesitas
  1. Audiovox CDM-8910 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
  2. Audiovox CDM-8910 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
  3. Audiovox CDM-8910 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
  4. Audiovox CDM-8910 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Use a spudger to lift away and remove the metallic frame (in blue).
    • Use the spudger to lift away the two electrical contacts (in red).
    • Use the spudger to lift away the speaker (in yellow).
  5. Audiovox CDM-8910 LCD Screen Replacement: paso 5, imagen 1 de 1
    • This is what the rear of the LCD screen should look like before proceeding. Note all necessary connections are undone.
  6. Audiovox CDM-8910 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Use a spudger to lift away the LCD screen.
  7. Audiovox CDM-8910 LCD Screen Replacement: paso 7, imagen 1 de 1
    • LCD screen successfully removed!
Conclusión
Una persona más ha completado esta guía.
Kevin Jafarey
Miembro Desde 10/04/10
11 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-24, Regan Fall 2010 Miembro de Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 18
Todo El Tiempo: 2,911
