Introducción
This is how to remove the 5 screws and pry the logic board free.
Partes
No se requieren partes.
Hold the phone in one hand, slide latch, and pull to remove the battery. Hold the phone in one hand, slide latch, and pull to remove the battery.
  • Hold the phone in one hand, slide latch, and pull to remove the battery.
Agregar Comentario
Grasp antenna at its base and unscrew. Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly. Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
  • Grasp antenna at its base and unscrew.
  • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove small rubber insert from top of phone to access the top screw. Warning: Screws are very small and may be difficult to see while unscrewing. Unscrew all five (5) screws on the back of cell phone.
  • Remove small rubber insert from top of phone to access the top screw.
  • Warning: Screws are very small and may be difficult to see while unscrewing.
  • Unscrew all five (5) screws on the back of cell phone.
  • If screws do not remove after fully unthreading, gently invert and tap phone in hand until the screws come loose.
Agregar Comentario
Wedge back plate away from cell phone using the leverage from the plastic spudger. The volume control button on the left side of the phone will be loose. Make sure to carefully reinsert during reassembly. Detach logic board from LCD screen connector by gently detaching the small copper plate on the top right of the logic board. (shown circled in blue and detached)
  • Wedge back plate away from cell phone using the leverage from the plastic spudger.
  • The volume control button on the left side of the phone will be loose. Make sure to carefully reinsert during reassembly.
  • Detach logic board from LCD screen connector by gently detaching the small copper plate on the top right of the logic board. (shown circled in blue and detached)
Agregar Comentario
Pop the logic board out from the front of the cell phone. Before reassembly, be sure keypad is lined up with logic board. Before reassembly, be sure camera lens is properly aligned at the top of the logic board and volume controls are in place.
  • Pop the logic board out from the front of the cell phone.
  • Before reassembly, be sure keypad is lined up with logic board.
  • Before reassembly, be sure camera lens is properly aligned at the top of the logic board and volume controls are in place.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Aaron Shaw
Miembro Desde 15/04/10
150 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 28-31, Regan Spring 2010 Miembro de Cal Poly, Team 28-31, Regan Spring 2010
CPSU-REGAN-S10S28G31
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,582
